I have installed the Navisworks 2014 and cannot figure out how to make the Switchback work for the Revit 2013 file that I am using. Any suggestions or ideas on how to get this command to work?
Solved by rcodys. Go to Solution.
If you have not installed the Navisworks Export Utility, you can download and install from the page below:
http://www.autodesk.com/products/autodesk-navisworks-family/autodesk-navisworks-nwc-export-utility
I would then make sure to enable switchback for 2014 with Revit by going to the Add-ins tab > Navisworks Switchback 2014.
