Navisworks General
Active Contributor
jayala79
Message 1 of 2 (403 Views)
Global Options XML file
403 Views, 1 Replies
08-23-2012 12:09 PM
I know that you can change your settings in global options and export them as an XML file to import to other stations, but is there any way to re-path the directory that NavisWorks looks for the XML by default? For instance, if we install NavisWorks on numerous computers do we have to load the global options XML file on each PC or can we place the XML file on a server and have all NavisWorks stations pathed to that location?
Employee
JeffH_ADSK
Message 2 of 2 (371 Views)
Re: Global Options XML file
08-29-2012 03:51 AM in reply to: jayala79
Hi there,
Using the Global Options under General/Locations you can specify Project or Site Directories to be examined for Global Options, workspaces, DataTools profiles, avatars, rules, etc. Project takes precedence. This can be a network path if so desired. It is treated in a similar manner to the user's profile directory & the equivalent for All Users.
It is even feasible to lock options via the Options Editor & export so that when Project settings are picked up, they cannot be changed by users on their machines.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
You are not logged in.
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
