Navisworks General
Valued Mentor
Message 1 of 19 (2,517 Views)
Accepted Solution
From ArchiCAD to NavisWorks
2517 Views, 18 Replies
10-13-2011 10:27 PM
Hi all,
I've seen in the documentation that it should be possible, but the question is: How ?
-> Do I have to install Simulate 2012 on the same machine as ArichiCAD ?
-> Do I have to make special choises in the installation wizard for something ?
-> What do I have to do in ArchiCAD to export to a NaviWorks format ?
Or After installing Simulate 2012, Can I just open or append the ArchiCAD file format ?
kind regards,
Employee
Message 2 of 19 (2,510 Views)
Re: From ArchiCAD to NavisWorks
10-14-2011 03:49 AM in reply to: Patrick_Aps_9121
Hi Patrick,
The direct ArchiCAD export is feasible, creating an export NWC file that is read into Navisworks. You must install ArchiCAD and then the exporters portion of the Navisworks installer (either from Simulate or the stand-alone exporters version). This installation order allows the exporters installer to detect ArchiCAD. You then select the version of ArchiCAD to install against in the Navisworks exporters installer's configuration.
Once installed, you can export NWC from ArchiCAD by doing a Save As and selecting NWC. There are also indirect routes e.g. by exporting IFC from ArchiCAD, but the native ArchiCAD starting point is almost always the best route for model fidelity.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Valued Mentor
Message 3 of 19 (2,501 Views)
10-14-2011 12:20 PM in reply to: JeffH_ADSK
Ok, but where do I find or download these exporters ? Are they included on the DVD of Simulate or Manage ?
Currently I have network licences of both those producs. Will the stand alone exporters use one of those licenses when used ?
*Expert Elite*
DarrenP
Message 4 of 19 (2,498 Views)
10-14-2011 03:18 PM in reply to: Patrick_Aps_9121
here are the exporters: http://usa.autodesk.com/adsk/servlet/pc/item?id=13947462&siteID=123112
i don't know how archicad works
but with autocad you type nwcout in the command line this doesn't use up a license of navisworks
Product Support
Message 5 of 19 (2,478 Views)
10-18-2011 03:46 AM in reply to: Patrick_Aps_9121
If you have Simulate or Manage on the machine you will be able to go to Add/Remove programs and modify the installation of the Autodesk Navisworks 2012 32 (or 64 bit) Exporter Plugins, and include the ArchiCAD exporters in the installation.You will need to have the Subscription release if you wish to install the NWC exporters on ArchiCAD 14 or 15, more details can be found when you log into the Subscription Center.
This will add NWC to the list of files you can 'Save As' in ArchiCAD.
NWC export does not need a full license.
Lee Mullin
Product Support Specialist
Global Services
Autodesk Ltd.
New Member
LasseBorg
Message 6 of 19 (2,433 Views)
10-28-2011 01:51 AM in reply to: lee.mullin
Hi Lee!
I've been searching Subscription Center for NWC Exporters for ArchiCad 14-15 but can't find it.
What do I search for, e.g name of download?
I've got the Autodesk_Navisworks_Exporters_2012_Multilingual_Win.exe but that doesn't include Add-On's for 14 and 15.
Best Regards
L. Borg
Product Support
Message 7 of 19 (2,409 Views)
10-31-2011 09:55 AM in reply to: LasseBorg
You'll need to find the "Interoperability Enhancements for Autodesk Navisworks 2012" then in that page search for "Exporters Update for Autodesk Navisworks 2012 - Multiple Languages*".
This contains all the exporter plugins, and can be installed as a seperate installation (it does not need any earlier versions installed).
Lee Mullin
Global Services
Autodesk Ltd.
Valued Mentor
Message 8 of 19 (2,362 Views)
11-11-2011 11:47 AM in reply to: lee.mullin
I also found out that the Plugin is only for ArchiCAD 13, while the most recent version of ArchiCAD is 15.
I tried nevertheless but the plugin did not install.
However, ArchiCAD could export the 3D to an DWG file, that could be appended in NavisWorks without issues.
Even the basic colours appear in NavisWorks.
As I am only interested in the geometry and not in high end renderings, this DWG route is sufficient for my needs.
Product Support
Message 9 of 19 (2,339 Views)
11-15-2011 06:52 AM in reply to: Patrick_Aps_9121
That's a shame, it may be that these options are not visible with the Subscription version of the Exporters if you have 32 bit ArchiCAD on a 64 bit system for example.
Here is a screenshot of the Add/Remove Features on my machine with the Subscription Exporters on a 64 bit machine under the Autodesk Navisworks 2012 64 bit Exporter Plug Ins. I don't have ArchiCAD installed but they should show up in this menu regardless as long as the right version is installed.
If the DWG output is a suitable workaround though then that is great.
Lee Mullin
Global Services
Autodesk Ltd.
Valued Mentor
Message 10 of 19 (2,322 Views)
11-18-2011 02:24 AM in reply to: lee.mullin
Is was a 32bit ArichCAD on a 32-bit Win7.
However, I might have missed the scroll bar to see if there is a ArichCAD 14 and 15 below te ArchiCAD 13.
Is there a way to manuall way to install just this Exporter ?
You are not logged in.
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
