When is the Freedom 2014 download going to hit the Autodesk webpage?
http://www.autodesk.com/products/autodesk-navisworks-family/autodesk-navisworks-freedom
Simulate and Manage are already out, so I would expect Freedom would be too. I need this ASAP.
Solved by DarrenP. Go to Solution.
If you have Simulate or Manage, you should be able to use either of them to create a Freedom-only or Simulate/Manage + Freedom deployment while you wait.
its there now
DarrenP
Here is the link for download:
Those links link to the download page but the actual download link for 2014 is broken.
Thanks for bringing this to our attention Todd!
I've just contacted the group responsible and will let you know once it has been resolved.
Thanks all. All fixed.
I was needing this as a link to send to a client to download.
I need to download Navisworks Freedom 2014, when I click on the links you have provided it suggests it will download Navisworks Freedom 2015. Is there anyway of getting an older version please, I need 2014 for my machine.
Thank you
Hi @Anonymous and welcome to the Community!
Here is your Autodesk Navisworks Freedom 2014 32-64 bit download link.
*For all other users: The link above will expire 30 days after this post was created. If the download you need isn't available in the Virtual Agent please create a new post requesting a new one. Please also note that not all previous version downloads will be available.
Thank you!
As already stated in another tread, a more permanent link is needed:
Indeed, why are the Freedom 2014 downloads not mentioned on the page
http://knowledge.autodesk.com/support/navisworks-products/downloads#?sort=PublishDate
The Freedom 2013 downloads still are, so there is no reason NOT to do so, as Freedom 2014 is the last and definitve 32-bits version available.
