Navisworks General
Member
sylvesjd
Message 1 of 3 (167 Views)
Frameworks Model only Showing Sparse Lines in Navisworks
167 Views, 2 Replies
04-05-2012 06:46 AM
When I create an NWD file from Intergraph Smart Plant Review files one particular Frameworks PRP file comes across with only the sparse lines. The PRP file renders normally in Microstation, but I cannot figure out why Navisworks only puts the sparse lines in the NWD file. Has anyone seen this before?
Valued Mentor
Patrick_Aps_9121
Message 2 of 3 (138 Views)
Re: Frameworks Model only Showing Sparse Lines in Navisworks
04-23-2012 12:02 PM in reply to: sylvesjd
no,
I always use this sequense
Open FWP (not using the PDS interface, but direct from the start menu)
freeze the view "Isometric" into a new PRP file. A DRV file will be created.
Do not include FWP models in scheduled label builders or scheduled DesignReview sessions
Delete existing nwc files
append the FWP file manually in the NWF
Member
sylvesjd
Message 3 of 3 (136 Views)
04-23-2012 12:19 PM in reply to: Patrick_Aps_9121
Yeah, I wound up doing that for the one FWP file one time. I was looking for a solution that would still allow use of the scheduled label builder and Navisworks scheduled batch publisher each night without any manual intervention on my part. Thanks for the input.
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Ask the Community
