Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
File Save Options Setting a default
5 REPLIES 5
thniels
943 Views, 5 Replies
We find ourselves constantly changing frame rate from 6 to 24 in File Options in Simulate. Is there a way to set this value by default or is it bound into the software?
5 REPLIES 5
JoAnn_Hogan
in reply to: thniels
There's no actual place to reset the default FPS to a personal setting. That is part of the Navisworks program as a standard. Only the developers can change that. However there are a few settings that we have found applicable namely:
  1. Change the Frame Rate manually
  2. In the options Editor dialogue box > under display > deselect "Guaranteed frame rate"
  3. Options you can change in your export dialogue box for FPS
Those are the only variables you can change
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
thniels
in reply to: JoAnn_Hogan
Ah, that's a pity. So what you are saying is, that we need to send some of our famous Danish cookies to California and wait a bit while the developers munch away Smiley Happy. Or, in other words: I really think this should be possible - the entire File Options dialog should be set in XML.
JoAnn_Hogan
You could post this idea in the IdeaStation. So they know what to work on while munching away
Jo - Ann
thniels
Oh, there doesn't seem to be an IdeaStation for Navisworks. Am I missing something?
JoAnn_Hogan
http://www.augi.com/ Is the best place to post your ideas for now. Hopefulle they will create one for the community soon.
Jo - Ann
Rail Community
