Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Exporting animations with presentersettings Navisworks Manage stops
2 REPLIES 2
oedsdemeer
776 Views, 2 Replies
When exporting an timelineranimation (with presenter rendersettings) the computer stops after a while. We have tried it on different computers ( even on a computer that was purchased to create animations, etc.) and methods (avi compressed, avi non commpressed & images) but over a time the text: “There is not enough memory to complete this render. Please increase the amount of memory available” emerges.
How can we fix this?
2 REPLIES 2
john.lipp
in reply to: oedsdemeer
Hi oedsdemeer
To test, does the same issue occur if you temporarily delete all materials from the materials tab.  If not, perhaps there are reflective/transparent materials that are causing the issue.
If the issue remains, I would check if the same issue occurs if you drag the Recommended > Standard Light Studio in the palette of the lighting tab of Presenter.  Perhaps you have a complex lighting environment with many sources.
If the issue remains, I would try doing both of the above.
If the issue remains, I would try turning off everything but surfaces under Item Tools > Render Style and try exporting the simulation.
In the Animation Export window, try clicking the options button under output to set a different compressor.  Please send a screenshot as this will show the resolution and FPS settings.
If the issue remains, try exporting to JPGS to see how many frames are able to be exported before the memory issue occurs.  Perhaps you could set the FPS setting to something lower that would allow that many frames while still finishing the animation without a memory error.
How much RAM is installed on the machine, what is the OS, and I’m assuming it is 64-bit correct?
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
jaka.senekovic
in reply to: john.lipp
Hello, i have a problem by making a Timeliner simulation animation the rendering stops by 92.1% (JPG and avi export).
It worked for first two weeks and than the rendering stops by a procent %.
I have allerdy adjusted the general settings autosave to 32 GB and than it was working again for one week.
Now I have problems again eaven with this setting on.
Can somebody help me?
Rail Community
