Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Error message "There were errors encountered while opening the Revit model"
4 REPLIES 4
lee.mullin
2265 Views, 4 Replies
If you recieve the error "There were errors encountered while opening the Revit model. Please open the file in Revit and fix the errors" then you will need to open the file in Revit, resave it then you can bring it into Navisworks. More details in the link below
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
4 REPLIES 4
lee.mullin
in reply to: lee.mullin
Hi, we have recently had the same message when trying to append in a 2016 MEP rvt file into 2017 Navisworks manage, are there any fixes for this?
I have tried,
Re-opening the rvt file,audit, purge sync. - did not work
append in Local, detached and central file - did not work
removing all links and dropped in CAD files - did not work
Migrating/copying model to a new project - did not work
The strange thing about this problem is that up until around 4 weeks ago it appended in fine (although excruciatingly slowly!)
Any help would be much appreciated
thanks
Pete
semko_dm
in reply to: peterkennedy668
Hi! I have this problem too. Did you found any solution?
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
tim.westCZWFZ
This should NOT me marked as SOLVED as the link does not describe in the least 'HOW TO' fix the problem. . .
"This means you will need to fix the file in Revit 2013, this fixes parts of the model that cannot be converted inside of Navisworks. When you save the file in Revit 2013, Navisworks can then load those elements."
Please explain HOW to 'fix the file in Revit 20??' this happens far too often for my liking, and requires more steps in the federation process
Rail Community
