Navisworks General
hardsniffer
Message 1 of 4 (898 Views)
Accepted Solution
Connect Autoplant (Access DB) to Navisworks 2012
898 Views, 3 Replies
11-22-2011 03:37 AM
I have Autoplant XM installed and Navisworks manage 2012. When I hit the Datatools button I see 5 Autoplant items: Autoplant central multi-project, central single project, local equipment, local nozzle, local piping. wich of the boxes needs to be ticked? And what are the settings for each item?
I want to create an embedded nwd file with included data of valvenumber, linenumber, specs etc.
Thank you for your help,
Stephan
Product Support
lee.mullin
Message 2 of 4 (877 Views)
Re: Connect Autoplant (Access DB) to Navisworks 2012
11-23-2011 08:54 AM in reply to: hardsniffer
These are Autoplant settings, you would need to check the type of installation and type of project you have set up in Autoplant, if you are not sure, please speak to the person who set the Autoplant project up.
You can embed the database properties but these will only be visible in Simulate and Manage.
Lee Mullin
Product Support Specialist
Global Services
Autodesk Ltd.
jorge.garza
Message 3 of 4 (312 Views)
10-15-2013 12:29 PM in reply to: hardsniffer
Did you ever get an actual answer on this issue? i have been trying myself for servral version and nothing. Please advice. Thanks.
Active Contributor
snijdam
Message 4 of 4 (299 Views)
10-15-2013 01:28 PM in reply to: jorge.garza
We switched to Autodesk Plant Design suite ultimate 2014.
The best choice for us. because of crappy service of bentley.
I never got it to work.
You are not logged in.
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
