After setting up, running my clash reports, and resolving all clashes, I want to export a clash detection report that shows no more clashes. When I try to do so, the button "Write Report" is not live. I have tried to use the Saved Viewports, but that is not giving my what I need. I need to create an HTML type file that shows there are no clashes. Suggestions? Any ideas would be greatly appreciated!
Thanks!
Have you selected what type of clashes to publish. You normally have to select or deselect "CLEARED" "ACTIVE" "NEW" "OLD" "APPROVED" "REVIEWED". I f none of these are checked then you cannot create a clash report.
I had the same problem. The solution is very simple. In the output settings, under Report Type, just change from "Current test" to "All tests (separate)". This will export all your reports separated, including those with 0 clashes in them.
Best!
