Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Clash Report Customization
2 REPLIES 2
ari.monteiro
1882 Views, 2 Replies
I customized my clash report by editing the “clash_report_html_tabular.xsl” file. I defined new formatting for my clash reports, adding two new columns and a new logo (Figure A).
On the report head, after the field named “Projeto” I want put the name of Navisworks file. Is possible capture this data from Navisworks file and write it into report?
I noted that “clash_report_html_tabular.xsl” file has some reserved variables for specific parameters which ones are used to formatting the clash reports, such as: showSummary, showClashPoint, showLayer, etc.
Is there a variable related with the name of Navisworks file for use in this situation?
I’m using Navisworks Manage 2014 with SP1 e hotfix 3 applied.
I appreciate any suggestion!
Thanks!
2 REPLIES 2
Lance.Coffey
in reply to: ari.monteiro
To find if one of the reserved variables includes the filename that the report is being written from, you could take a copy of the XSL file, and update it to include every variable in the report. If you find one that includes the file name, you can then use just that variable in your original XSL file.
Lance Coffey
Technical Support Specialist
jorge.garza
in reply to: Lance.Coffey
Can you tell me where to find these variables? Thanks
Rail Community
