This (the change unit application) does not work on my version of Naviworks Freedom.
I recently posted a question about this however, the solution provided did, or does not work with Naviswork Freedom.
I've have seen the change units setting in the "Navisworks Manage" and I also belive this was the case with Navisworks Simulate. Right now, I have Naviswork Simulate 2011 however, the file I have tried to open will only work with Naviswork Freedom 2012.
Is there some update, or service pack for the viewer that I am missing?
Please let me know. Thanks.
Milt a.k.a.-Drafter1981
Solved by Milt-Fitz. Go to Solution.
Solved by lee.mullin. Go to Solution.
You'll need to access the Options Menu from the Application button in the top left corner then go to Interface > Display Units as the attached pictures show.
Please confirm if this resolves the issue.
Thanks Lee....
This post clarifies which option box and settings to use.
It looks as if I was using "File Options" under the Home pulldown tab.
I did not realize there was another "Options" tab, or box, next to the exit program tab.
Thanks again.
Milt (a.k.a. drafter1981)
