Hi.
I have tried to make my own colours in the txt-file when I import the rvm-file made from PDMS.
I want a yellow, so I write 100 100 0 (in R, G and B order). The txt-file will only allow numbers from 0-100, sp I assumed, that when I typed 100, it will be transformed to the normal 255-value, but inside Navisworks,. the 100-value is now transformed inthe a value of 156.
This means, that I can never exceed the value of 156 inside Navisworks, other than change all the colours manually.
Can you please change this, so the value of 100 in the txt-file will be replaced with 255, and not 156 inside Navis.
Thanks.
Can someone take a look at this.
If I set the value in the txt-file to 100 100 0 - it produces an RGB-value of 156 156 0. (yellow/green-thing)
Try it here:
http://www.colorschemer.com/online.html
I simply want it to produce an RGB-value of 256 256 0 (clean yellow) - but how do I write this in the txt-file. It it obviously not possible.
Please help!
