Can you "Save" & Number a View with 3D Plus Measurements (Distances etc.) in NAVISWORKS FREEDOM?
Thanks Patrick---
How can I Save a View in Viewpoint?---
As there is an Option in FREEDOM to Save, Load & Playback
a View, Under Viewpoint/Save, Load & Playback---
however, when I use this Option to "Save" the View
is not Saved---how do I save the Views and Playback?
Please let me know---Thanks---
Again, NO you can't in Freedom.
you can only Load the Viewpoints or Playback the Animations that (somebody else) has saved in the NWD file.
To Create, Save, Export and Viewpoints and Animations, you need Navisworks Simulate or Navisworks Manage.
Thanks Patrick.
I have a qestion on the same subject.
In NAVISWORKS MANAGE---
When I Create a View, how do I "Save Selection"
or "Save Viewpoint" in a manner that Selections/
Views can be Retrieved as they were Saved and I can
go back to the Original 3D Model as needed?
I have Created Selections/Views---but cannot go back
to different Selections & Views and also go back to
the "Original" Complete 3D Model.
Thanks Very Much---
Thanks Patrick.
However, I cannot mark Save/Hide Attributes Box as it appears
"greyed-out" each time---how do I handle this?
Also, the View that I get as default is the clipped View
that I have Created---how do I get the View for the Original Full
Model again---and juggle between Full Model Views and
clipped Views that I will Create? I believe that all this is done
in MANAGE, as per what you mentioned---and then Shared as NWD
in FREEDOM---is this correct? Apologize, but I am new to NAVISWORKS.
Please provide detailed Instructions---with Full Commands---
would greatly appreciate it.
Thanks Very Much---
