I am trying to attach a MS project file to my timeliner, and I am running into an error (see attached image). I get a window that says the project can't be opened. Any suggestions?
Solved by k.jayavijayan. Go to Solution.
Did you install Microsoft Project 2007?.
MS Project should be installed in the PC before you linking them into the timeliner.
I Have the same problem, i already installed Microsoft Project. Need help. Reggards
