Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Can Revit 2014 export to a Navisworks 2013 file?
2 REPLIES 2
391 Views, 2 Replies
I am aware that Revit can export to an NWC file with the download of the Navisworks Exporters plug-in.  However, my question is whether or not Revit 2014 can export to a 2013 NWC file?  I work for a sub, and we do our modeling in Revit 2014 and want to be able to export to an NWC file that can be opened by the General Contractor (who uses Navisworks Manage 2013) to perform clash detection.  I have not yet downloaded the exporting software, so am just wondering before doing so.  Any information helps.  Thank you.
2 REPLIES 2
dgorsman
You can try installing the Navisworks 2013 exporters in Revit.  If that doesn't work, then you could also open the NWC in Navisworks, publish to NWD, then downsave the NWD to 2013 for them to use.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
in reply to: dgorsman
Thank you very much for the response! I will try it out and see if it works!
Rail Community
