I have Manage 2013 and Simulate 2013. In Simulate 2013 I hit the Batch Utility button and I get a Blue Wheel for a sec and then nothing. In Manage the Batch Utility UI popps up, but after files are selected and added to the queue and the batch is run, blue wheel for a sec, and then nothing. Any ideas?
Please respond to the following:
1. Did it ever work in 2013 for you?
2. Did it ever work in 2013 for anyone in your firm?
3. Do you have update 1 installed? http://beyonddesign.typepad.com/posts/2012/06/service-pack-1-now-available-for-autodesk-navisworks-2...
4. Did you try a repair install. Insert the media and choose repair when its offered.
Thanks for posting.
Brad, I took a look for similar cases and came up short. I'm more of a Revit tech thank Navis, but it the application is working without the update I'd be inclined to leave it as is for now. If you have some downtime later then try re-installing the updates to see what happens.
