Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Autodesk Navisworks Freedom 2012
3 REPLIES 3
606 Views, 3 Replies
Good Morning,
I have installed Freedom 2012 on a Windows 7 Enterprise laptop and when I attempt to run the app I get the cursor indicating activity then nothing.
The laptop is well with spec and exceeds all the system requirments to run the application
I have updated the graphics driver to the latest version still unable
Has been installed and uninstalled on multiple occasions still unable
Have disabled Anti Virus thinking this might be preventing it still unable
Installed the app on idenitcal laptop and runs perfectly
Everytime I try and run app roamer.exe runs for a short time and in event viewer the application error is logged
Faulting application name: roamer.exe, version: 9.0.69.686, time stamp: 0x4d7f9708
Faulting module name: PGHook.dll, version: 3.0.291.0, time stamp: 0x4f1ed4f9
Exception code: 0xc0000417
Fault offset: 0x000000000001b030
Faulting process id: 0x974
Faulting application start time: 0x01cd47b9058447f3
Faulting application path: C:\Program Files\Autodesk\Navisworks Freedom 2012\roamer.exe
Faulting module path: C:\Windows\system32\PGHook.dll
Report Id: 43fb38d5-b3ac-11e1-8331-463500000031
Any ideas greatly appreciated !
C
3 REPLIES 3
JeffH_ADSK
Hi there,
PGHook.dll is not supplied as part of Navisworks. It is, as I understand it, part of Avecto's Privilege Guard product. Navisworks should run under a standard user account, but it has not been tested under third party products that manage user rights, as far as I am aware.
Can you try Freedom without Privilege Guard active? Can Privilege Guard be instructed to treat Freedom as a normal user application?
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Read entry about Avecto earlier and just went in one ear and out the other
Removed Avecto Freedon now works ok
Patrick_Aps_9121
NavisWorks (any version or flavor)
is incompatible with Avecto Privilige Guard 2.7 (Build 52)
the solution is to upgrade Avecto Privilige Guard 2.7 (Build 63) or above
or to downgrade to Avecto Privilige Guard 2.6 (Build 151)
Rail Community
