Navisworks General
Product Support
Message 1 of 4 (446 Views)
Accepted Solution
Auditing a Navisworks model for distant objects
446 Views, 3 Replies
04-20-2012 03:54 AM
Do you get any of the following problems within Navisworks?
  • When you render your model through Presenter, only the background shows, or you seem to get holes or triangles missing from a render
  • When you navigate the model it looks like you have a section plane in front of you, as describedhere
  • Jerky performance when navigating
  • Model disappears when rotating around the model
  • When you zoom out the model disappears
  • Two faces seem to occupy the same space giving a jagged looking surface
Lee Mullin
Product Support Specialist
Global Services
Autodesk Ltd.
Product Support
Message 2 of 4 (445 Views)
Re: Auditing a Navisworks model for distant objects
04-20-2012 03:55 AM in reply to: lee.mullin
Message 3 of 4 (344 Views)
05-28-2012 05:41 PM in reply to: lee.mullin
Many issues with distant objects can be avoided by unchecking ( do not import) lines under Options --> File Readers --> Convert Lines.
My issue with CADPIPE files went away i.e. the files being processed by Navis 2012 Manage no longer "exploded" scattering debris out by Pluto.
"To see things in the seed, that is genius". Lao-Tzu
New Member
ebsarmiento
Message 4 of 4 (278 Views)
08-07-2012 12:57 PM in reply to: RobinsonG
RobinsonG......you are the man!
Worked great. Thanks!
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
