Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Animator and Key Points
1 REPLY 1
prhawco1
288 Views, 1 Reply
I'm rendering an animation in Navisworks using Animator.  I have a camera with quite a few keypoints set.
Is there a way to add 2 seconds between keypoints and have it push all the other keypoints out 2 seconds as well?
Right now everytime I make a timing change I have to change every other keypoint in the scene / camera manually.
Paul
1 REPLY 1
john.lipp
in reply to: prhawco1
Hi prhawco1
Unfortunately, you aren’t able to insert time in between keyframes and have the later keyframes shift.  You are also, unable to multi-select keyframes to drag the multiple keyframes to a later position.  This leaves right-click > editing each keyframe individually by adding the extra time or manually dragging each into the later position as you've been doing.
There is an existing wishlist item for this functionality logged with development.  I recommend sending this as an enhancement request through the following link:
The information you send through this page is reviewed directly by our development team, and coming from an end user, this information offers a compelling business case.
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
Rail Community
