Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Animation/Timeliner issue
2 REPLIES 2
ari.monteiro
1493 Views, 2 Replies
I need simulate the elevation of one crane on TimeLiner. Using the Animator I created a animation with two animation sets to represent my simulate. Each animation set moves my crane on Z axis by 6 meters.
I don’t want to see the crane's positions  between start and end points of animation. So, to solve this issue I turned off “Interpolate” option of each key frame (Figure 1).
After, I created two tasks on TimeLiner with 2 months. Then, for each task I linked one animation set (Figure 2). Everything seems OK. But, when I execute the Simulate command I don’t have the result that I want.
The animation does not run with simulate command. Only when the command terminates the animation sets are triggered. So, what can I do to solve this issue?
I attached a NWD of my Navisworks project to analysis. I’m using Navisworks Manage 2014 with SP1 e hotfix 3 applied.
Tags (2)
2 REPLIES 2
in reply to: ari.monteiro
Your set was not created properly, you want the items source file to be equal to crane2.skp. Works fine when corrected.
ari.monteiro
Hi Jean!
I cheked the search set. It's OK. The serch set is equal to crane2.skp.
I found the problem...the animation sets were wrong!
The animation sets were not assigned properly to search sets. Smiley Surprised
Rail Community
