Okay, it's been a few years since I added the NWC exporter for ACAD, since I've been in RAC for a long time now. Am working a Project for an Electrical Contractor, we're getting dwg files from the Mech Contractor in 3D (CAD DUCT I think). Anyway, I know NWM will directly read the dwg files, but I wnat to test and used the NWC files from the drawing files. I just installed NW SP1 and the undated exporters, but now have a BRAINFART about two to load the exporters into ACAD. I just checked my ACAD, and it's NOT under the Plugins Tab.
MIke
Solved by lee.mullin. Go to Solution.
its not going to be
you have to go to programs/features in the control panel and select the navisworks exporters and choose uninstall/change
DarrenP
Darren, I did that..it shows it as being installed for ACAD................my problem is, I cannot remember where or how to find it in ACAD. thus the BF...............do i need to do an appload or something. Like I said, the last time I used NW with any ACAD Vertical was for 2008 ADT.
M
try typing in NWCOUT
DarrenP
Hi Maike,
You'll need to load the ARX plug-in into that application. I've added a section of the help file below.
To load the ARX plugin in an AutoCAD-based application
Let me know if this doesn't work
AHHHHHH, now I remember.....................that's what happens when you get old(er)....the little things slip past you.
Thanks Lee and Darren.
Mike
