Navisworks General
Distinguished Contributor
Message 1 of 4 (391 Views)
3d faces from acad render black....
391 Views, 3 Replies
04-03-2012 06:08 PM
I extracted 3d faces from a c3d 2012 surface, and split between a green and red layer.
When I pull into NW Simulate 2012, the faces show fine in shaded mode, but black in full render mode.
If I do not extract faces, but pull in dwg with full c3d surface, things work fine, but i need control of faces on different layers for coloring.
Any obvious things to check here? I am using full lights for lighting, rendering using presenter.
Active Member
Message 2 of 4 (388 Views)
Re: 3d faces from acad render black....
04-04-2012 12:23 AM in reply to: jmaeding
Did you check the material tab in presenter? If you pull in dwg file there sometimes is a material called by layer which is totally black. Why this is here no one can tell me. But you need to delete it because else you end up with black objects in your render.
Product Support
Message 3 of 4 (386 Views)
04-04-2012 02:44 AM in reply to: psnl
This should now be resolved in the Navisworks 2013 release.
Lee Mullin
Product Support Specialist
Global Services
Autodesk Ltd.
Message 4 of 4 (374 Views)
04-04-2012 08:45 AM in reply to: psnl
that was it, delete the bylayer material.
You would think stuff like this would get caught in the most super basic testing of the product.
thanks
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Ask the Community
