Hi all,
Under the cateroy "DWF-Pipe", i have two properties, for example, "LineNumber" and "Spec"
In my excel file, there is a field "name" which is the concatenation of "LineNumber" and "Spec"
However, i don't find any solution to write it in my SQL string.
The SQL string would be like:
SELECT * FROM entity_data WHERE "name"=concat(%prop("DWF - Pipe","LineNumber"),%prop("DWF - Pipe","Spec"))
I would like to be able to write something like that to:
SELECT * FROM entity_data WHERE "name" like %prop("DWF - Pipe","LineNumber")
But it seems that we can only match "name" to a property wich the exact same name.
Has any one faced the same issue?
I am afraid what you are trying to do is not possible.
The "Name" should always match to a property using the equal (=) operator.
Typically this expression would include a Navisworks tag which fetches model data to participate in the condition);
SELECT weight FROM entity_data WHERE name=%prop('Item','Name');
This assumes a table called entity_data with two fields, weight and Name, where Name is the same as the Name of Items in the Navisworks model
Also see here:
http://beyonddesign.typepad.com/posts/2011/09/datatools-links.html
What about using an AND operator to match 2 fields? I tried this and it doesn't seem to like it. The reason I need to use 2 fields is because some of the reference file element in the model I am opening have the same Element_ID. meaning I have to match Element_ID AND reference file name. Thoughts? This is what I write and it isn't working...
SELECT * from [Equipment$] where "Element_ID"=%prop("Element ID", "Value") AND "DGN"=%prop("Item", "Source File");
Hi, guys,
I'm trying to connect to a sql database on a personal server but I can't. Do you have any leads I can study to get the right information in?
Hi Remy,
Without knowing what you have tried so far, here is the query (SQL string) we use in DataTools to link to an SQL database (in DataTools, ODBC Driver = SQL Server). Note that you'll have to create a connection to every table housing data. It can't be done in a single connection. In the example below, I am showing a single connection to one table in the database...
SELECT * FROM [H355025DataMart].[dbo].[NV_EQUIPMENT] WHERE "Mstn_ID" = %prop("Element ID", "Value") AND "Mstn_Filename" = %prop("Item", "Source File")
where;
H355025DataMart = SQL database
NV_EQUIPMENT = is the applicable table to pull from
Mstn_ID = the column in the table with the unique identifier to match against Element ID value in Navisworks
Mstn_Filename = the column in the table with the filename to match against Item Source File in Navisworks
In our case we have a second connection to a table housing piping data. Subsitute NV_EQUIPMENT with NV_PIPING and the rest of the SQL query is the same.
Hope that helps.
Cheers,
Austin.
