Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
dxf export fails
9 REPLIES 9
Message 1 of 10
dmulvang
807 Views, 9 Replies
dxf export fails
Hi.
When exporting a model of a process plant to dxf, all straight pipes are missing in the resulting dxf file. Has anyone experienced something similar?
Dag Magne Ulvang
CMR AS
Norway
9 REPLIES 9
Message 2 of 10
JeffH_ADSK
in reply to: dmulvang
Hi Dag,
Do you mean DWF export? Navisworks doesn't have the ability to export to DXF as far as I know...
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Message 3 of 10
dgorsman
When you say "... model of a process plant...", what program was used?
Message 4 of 10
dmulvang
Yes, you are correct. I did mean dwf.
Message 5 of 10
dmulvang
Originally the CAD model comes from a PDMS system, but I try to export to dwf from Autodesk Navis Works.
Dag Magne
Message 6 of 10
dmulvang
Hi again.
When taking a second look, it seems that it is all cylinder representations are missing, which includes straight pipes and the middle of a tank.
Dag Magne
Message 7 of 10
dmulvang
Hi again. Today I found a suggestion in a similar thread "Missing objects (cylinders) from a DWF file" that I will try out; "disable parametric primitives", and see if this fixes my export issue.
Dag Magne
Message 8 of 10
dgorsman
There may be object enabler issues at work here. There probably is an issue converting whatever PDMS is using for custom objects (as opposed to AutoCAD solids) into DWF format.
Message 9 of 10
dmulvang
Hi.
I have now tried a new export from Navis Works after disablling parametric primitives, but this did not help.
Dag Magne
Message 10 of 10
JeffH_ADSK
Hi Dag,
Could you attach the problem file (original from CAD application & NWD please if possible) along with reproduction steps or send it to Autodesk support as an issue please? I can make no promises as to when the issue will be addressed, but a reproduction case would greatly help speed investigation.
Jeff
Navisworks
Autodesk Ltd.
Rail Community
