Hi everyone,
Is it possible to zoom in/out in the reference views (plan and section)?
Solved by lee.mullin. Go to Solution.
You have two options, either to change the main viewpoint to a more zoomed in view and then in the plan view, right click > Look From > Current Viewpoint. Or alternatively right click in the plan view and Edit Viewpoint, you will need to manually change the Z axis to lower the camera and 'zoom in'.
If you are specifically looking for an interactive zoom then you should go to View > Split View and treat one window as your interactive view and one as your plan view.
Thank you Lee.
I was trying to do it with the Freedom version, but I can see the option is not available there.
I did it with simulate and saved it down to NWD.
Thanks again.
