Dear
I have problem with Visual Style Hidden comment. On Pdf output image is getting blurred. Can anyone to help me
Deepu
Hello there,
can you export a higher resolution? It´s the poor jpeg quality that affects the image.
The compression might be too high, therefore the artifacts which result from the lossy
compression result in the "blurred" look.
Do you export the PDF directly or do you print via PDF. Given you use Adobe´s Acrobat
Distiller you should be able to choose from a different range of image formats as well
as quality settings for each of them. Some of the compressed others uncompressed.
Usually you can set different defaults depending on the image type. If the image is black
and white, just 1Bit (black) or coloured you can set different compression methods and
image formats. That´s right, you can set up the compression for each image type seperately.
Vectors work splendid and can be scaled. With pixel based imagery you need to know
exactly which size you´re going to need. Go for 300dpi when using a 1:1 scale for prin-
ting. Everything above this range tends to look eighter pixelized or blurred. If you pass
the 140% line when scaling a picture this happens, dependent on the upscaling method.
Kind regards
Daniel
Dear Daniel
Thanks for the responce. Its not the problem of resolution. we are using Adobe´s Acrobat XI pro latest verson for making PDF from AutoCAD.
If i will change the setting in Visual style to 2d wire frame then the printout is clear.
If any one know how to change the setting in visual style then that will be great
Regards
Deepu
Ah okay,
sorry I misgot that- very (verrry) oftn this is the main problem at hand.
As soon as I get some info on the issue I´ll post it right here.
Have a splendid day anyways
