Dear all,
I have a problem that a view point is previously set before overriding of color to some element. The view show could not update the overriding of element. Could anyone help? My using version is 2011. Thx.
Lucppy
Solved by lee.mullin. Go to Solution.
If you right click a viewpoint and go to Edit there is a setting 'Hide/Required'. This controls whether save the state of models colors/transparencies/sectioning etc with ones set in that viewpoint. Switching this on means any colors set in that viewpoint as it is saved will be reapplied when you go back to that viewpoint.
You can set this for all future viewpoints in the main Options Editor for all models under Interface > Viewpoints.
