i am having the same problem but with the nwnavigator command. the nwload works and i did have to load it manually, everytime i try to load the nwnavigator.arx file it says it cannot load. i am 64-bit autocad 2011 and navis manage 2011 as well.
any help would be helpful?
thanks
Just to assist in this, nwnavigator and nwcout & similar showing up in AutoCAD & verticals as unknown commands usually means that the exporter failed to register the commands with that version of AutoCAD. Typically this is as a result of the AutoCAD application being installed subsequent to Navisworks, in which case re-running the setup of Navisworks to reinstall or repair the AutoCAD exporter should also fix it.
Appload bypasses the command lookup, and loads the exporter directly. As a side-effect of being apploaded, the exporter will register its commands, doing the same thing that the installer does.
Hope that helps,
Jeff
I can appload the exporter part of the software but the nwnavigator errors out and will not load. i have tried a couple of versions now and get no success. Please advise. nwdout works but not nwnavigator.
i am running xp pro, autocad mep 2011, and manage 2011. i have reloaded and repaired navis twice so far and it did not help.
thanks
chris
I cant find this file "\NWExport20xx\Autodesk Tech support"
Im using Autocad 2013, once I open naviswork 2013 folder thers nothing in there.
I can not install "nwload" in Autocad MEP 2014 (Navisworks 2014). During inslallation Autocad MEP 2014 did not ask about this function (when I worked in simple Autocad, I was asked about it). When I call "nwload", programm can not understand me. It seems to me, that Autocad MEP can't use this function...
Sorry for my English... I tried tj write correctly...
