Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Stairs and railings in "no level"
1 REPLY 1
601 Views, 1 Reply
Is there a way to make stairs and railings from Revit connected to the right level when imported to Navisworks?
I opened a .rvt -file in Navisworks 2013 and the "stairs"-objekt is in connected to the right level while the Railings, Runs and Supports-objects are in "no level" in the selection tree.
/ Malin
Tags (2)
1 REPLY 1
dennis
If you look in Revit, you will find that those object are not associated to the level either.  There may be a property of Reference Level, but not always.  If you want the model from Revit to be 'sliced' by level, then the NWC need to be produced that way.  Below are a couple links that will help toward that end:
http://appliedsoftwareblog.blogspot.com/2012/02/revit-to-navisworks-slicing-vrs-level.html
http://appliedsoftwareblog.blogspot.com/2011/11/setting-up-3d-views-for-levels.html
Rail Community
