Is there a way to make stairs and railings from Revit connected to the right level when imported to Navisworks?
I opened a .rvt -file in Navisworks 2013 and the "stairs"-objekt is in connected to the right level while the Railings, Runs and Supports-objects are in "no level" in the selection tree.
/ Malin
If you look in Revit, you will find that those object are not associated to the level either. There may be a property of Reference Level, but not always. If you want the model from Revit to be 'sliced' by level, then the NWC need to be produced that way. Below are a couple links that will help toward that end:
http://appliedsoftwareblog.blogspot.com/2012/02/revit-to-navisworks-slicing-vrs-level.html
http://appliedsoftwareblog.blogspot.com/2011/11/setting-up-3d-views-for-levels.html
