Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Show data from an AutoCAD file
3 REPLIES 3
donied
664 Views, 3 Replies
I have a 3d model in AutoCAD. I would like to attach text data to objects in the autocad file. I need the data to display in Navisworks when I hold my mouse over the object.
Is this possible?
3 REPLIES 3
bradwalsh
in reply to: donied
I have been able to have parametric information come across when exporting from Revit to dwfx and then opening in Navis.
Ixath
in reply to: donied
In Navis, go to GLOBAL OPTIONS -> INTERFACE -> QUICK PROPERTIES and enable those. You can use CATEGORY: NOTES to display information you enter for the objects in AutoCAD via the PROPERTIES -> EXTENDED DATA -> NOTES box.
It might not be exactly what you're after, but maybe it's a starting point.
donied
in reply to: donied
Thanks for you feedback. It looks like extended data is the way to go.
Rail Community
