Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Shared Coordinates not Locating Correctly in NW
2 REPLIES 2
Stephm419
1612 Views, 2 Replies
I have a multi discipline model. We are using shared coordinates. From Revit 2010 I export to .dwf.
Then append the dwf models into NW.
When I run the clash reports the FP model gives me hits.
When I look at it in Revit, it doesn't.
How can I check the location in NW?
2 REPLIES 2
dennis
in reply to: Stephm419
First off, I am not a fan of using DWFs with Navisworks, there are problems with orientation.  What I would recommend is using the Navisworks Export Addin that allows you to write out a NWC directly from Revit.  I would be more confident of alignment with this process.  You can get the exporter if you don't already have it via your Subscription Center website.
lee.mullin
in reply to: dennis
We would also recommend using Revit 2012 and the Navisworks 2012 Exporters as these support Shared Coordinates most effectively
This is the link for the Free 2012 NWC Exporters
http://www.autodesk.com/navisworks-nwcexportutility
Also the Navisworks 2012 release includes Switchback to Revit so you can quickly go back to the exact location in your Revit model
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
Rail Community
