What is the right workflow for this? other then overwriting the nwc's with the same filenames.
Before you launch your NW, move the old NWC out of the folder that NW is looking. Then put the new NWC in the folder, even if it is a different name. Launch your NW and load the NWF, when if gets to the load point for the moved file, it will not find it and ask for the replacement. Then you can select your new file.
