Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Quantification with IFC files
3 REPLIES 3
Mattcaffeine
1424 Views, 3 Replies
Hi all,
I've put a test IFC file into NW to try out quantification, I can get my windows to add in, and count them, but not to give me dimensions, I understand from importing a revit test that in the item catalog height =modelheight automatically. Can I repath these formulae to check against my IFC properties, in this case, 'overallheight'
Many Thanks,
Matt.
3 REPLIES 3
medietri
in reply to: Mattcaffeine
I am having the exact same issue -- any word?
Also, is it possible to take off a Search Set to a Catalogue Item so that new model objects will be automatically added to the Take Off?
Mattcaffeine
in reply to: medietri
Hi Medietri, I had some joy following the guidance from here:
http://de0qmbqba3hfm.cloudfront.net/attachments/149616/2 you have to find and edit (after saving a copy of the original, just in case) the takeoffpropertymap xml file.
Not sure about the search sets question, maybe post as a separate question.
Hope this helps,
Matt.
medietri
Thanks so much for your help.  Not an elegant solution, but at least there is one!
Rail Community
