Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Quantification re-setup possible?
3 REPLIES 3
nic.maes
965 Views, 3 Replies
I have a Navisworks project where i setup the quantification in Metric units in Meters.
I would like to change that to Millimeter.
Also, can i set the decimal place for the values in the Quantification?
3 digit places for millimeter values is a little to much?
Best regards
3 REPLIES 3
scott.a.green
in reply to: nic.maes
 Hello!,
To change the display units:
1. Click Application Button > Options.
2. In the options editor, expand Interface > Display Units.
3. Select the units you want from the Linear Units dropdown.
Does this help?
First Name Last Name or First Name.Last Initial
Public Facing Job Title
Link Name | Link Name | Link Name | Link Name
nic.maes
in reply to: scott.a.green
Thanks for the reply.
You can change the general display units,
I want to change the units for the quantification.
Apparently this is different from the display units.
I think once set you can not change the quantification units.
Best regards,
Nic Maes
scott.a.green
From testing Navisworks out on my end with Takeoff, it doesn't appear that this is possible without reloading the project from before you set up quantification-takeoff and then setting it up again with the correct unit values.
Rail Community
