Hi, there
I opened a .dwg file of Plant 3D 2012 in Navisworks Manage 2012. In the .dwg file, i have serval pipes.
Here is the problem: in Plant 3D all pipes look ok, but in Navisworks all pipes look like polygon cylinders, which should look like cylinders.
How can i do to make my pipes look like cylinders in Navisworks? Anyone knows ahout it, pls help me.
See the attched image if i did not make myself clear.
Solved by luoyong20061289. Go to Solution.
I am having this issue. could you explain the solution to this please?
Stassel
I beleive the OP found the layers were turned off in the orginal file that was being xref'ed.
He couls see them in the model but navis was not.
