I'm working with Revit and with Navisworks.
In Revit I've added a lot of phases to my elements. Now I want to use those phases also in Navisworks to add those elements in a easy way to my timeline.
Is this possible?
When I look to the properties of a Revit element, I don't find the property 'phase'.
It also means that it's not possible to make sets based on that property?
Is there a work-around?
Solved by Sushichump. Go to Solution.
When you export the NWC file, check your Navisworks Settings. You will want to "Convert Element IDs", "Convert element parameters = ALL", and "Convert element properties". Then when you check the properties in NW, you will see FOR SOME OBJECTS a tab for the Phase. I have notice however, that not all objects will pick up the Phases they were created in. Example: in my electrical models, the conduit shows the phase, while the panels do not.
I've changed the export settings, and now I get more information about the elements in Navisworks.
But still, I don't get the information about the phases into Navisworks. Is it because I've just a Generic Model in Revit?
I'll attach my Revit-file.
Check your selection resolution. If you open your selection tree, try grabbing the elements from a different part of the model hierarchy. You should get more columns than just the three that are shown in your image.
Cheers,
Scott
