Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Orbit tool - shortcut to non classic version
14 REPLIES 14
Message 1 of 15
Lars_A
1971 Views, 14 Replies
I'm using the "new version" for orbit, i.e. not the classic orbit version.
The shortcutkey for orbit tool is Ctrl+7, but when I use that I just get the classic orbit. This must be an error, so is there an alernative shortcut or a way to set that to get the "correct" version?
INFO: I have of course NOT ticket of for classic tool in my settings!
VERSION: Autodesk Navisworks Simulate 2012 (64-bit), version 9.0.0.69686
regards,
Lars A.
14 REPLIES 14
Message 2 of 15
alan.quinn
in reply to: Lars_A
See this link for information that may help:
http://images.autodesk.com/adsk/files/autodesk_navisworks_simulate_2012_user_guide.pdf
Go to page 142.
Thanks for posting.
Message 3 of 15
Lars_A
in reply to: alan.quinn
The shortcut key still only gives me the CLASSIC orbit!!!
i.e. problem remain
regards,
Lars A.
Message 4 of 15
kahn.cad
in reply to: Lars_A
Same problem here in 2021.
Need the solution for orbit direction when use keyboard shortcut Control+7.
It shoud go to NEW orbit, but Navisworks response as CLASSIC orbit which is reverse direction to the other Autodesk application. Very annoying to me.
Message 5 of 15
r.saczek
in reply to: Lars_A
Same Problem here - NavisWorks 2021.
Message 6 of 15
alan.johnson7YLND
in reply to: Lars_A
I just use > press and hold SHIFT key and press and hold mouse wheel, this gives me the 'new' orbit tool.
AJ.
Message 7 of 15
Hi, thanks for your reply, but it seems not to help in this case.
The think is, what we try to do, is to switch between the different navigation options using keyboard shortcuts:
Ctrl+1
Ctrl+2
Ctrl+7
to use the corresponding options, as they are presented in the following picture.
Now the problem is, that pressing Ctrl+7 does not toogle the 'new' orbit option, but always the 'classic' one.
The problem seem to be as old as to the day when the 'new' orbit option was introduced to NavisWorks.
I think it is been forgotten to map the keyboard shortcut Ctrl+7 to the 'new' orbit option.
If you were so kind to try the Ctrl+7 shortcut you will get an orbit that looks like in the following picture.
What we woult like to get then is the 'new' orbit looking like:
At the moment it ist possible to use the 'new' one only by pressing the button "7." as shown in first picture with the mouse. No keyboard shortcut possible.
Best regards
rs
Message 8 of 15
lumbera_darwin
in reply to: r.saczek
Hi @Lars_A  @r.saczek
If you want to edit the hotkeys, you can open and modify the "RoamerCommands.xml" located in C:\Program Files\Autodesk\Navisworks Manage [Version]\Layout.
Before editing, make sure you saved a backup for the original XML file.
From the original XML I found this lines and it shows these 2 kinds of orbit. The first maybe the classic and the second is the new one.
I have not tried this method as my computer is in administration mode, but if you could modify the above images to:
Let me know if this works.
Darwin
Message 9 of 15
r.saczek
in reply to: lumbera_darwin
Thank you @lumbera_darwin for you help.
Editting the xml file worked.
Message 10 of 15
you are the best! Worked perfectly.
Message 11 of 15
r.saczek
Tank You @lumbera_darwin
I can confirm that Your solution works.
Message 12 of 15
Lars_A2
Thank you @lumbera.darwin for the fix!
Works like magic 😊
Still think this should be fixed by Autodesk, time to switch to "new" orbit 😷
regards,
Lars_A
Message 13 of 15
brett_parkerLUEP7
in reply to: Lars_A2
Hello
I have raised a ticket with our development team to get this look at and resolved.
Assuming there is no specific reason it has been left, it should be updated in the coming future fixes.
Regards
Brett Parker
Navisworks Product Manager
Message 14 of 15
Lars_A2
in reply to: brett_parkerLUEP7
Excellent,
appreciate that you/Autodesk are reading/following threads like these!
regards,
Lars A.
Message 15 of 15
brett_parkerLUEP7
in reply to: Lars_A
This has now been changed and will be delivered with Navisworks 2025.
Brett Parker
Rail Community
