My Cadworks 2014 files (dwg, nwc or dwf) when opened with Navisworks Simulate 2014 will not show the solid properties of my piping just the centerline and wireframe. See image.
I have successfully installed the Service Pack 1 and the Hotfix; this has eliminated the crashing but not the visibility issue. Any thoughts and recommendations? Anyone?
Solved by dgorsman. Go to Solution.
Like any other product, AutoDesk or third-party, using custom objects, you will need the correct object enabler installed. You may need to re-install it to register it with the Navisworks program.
