I need your help, I have to make a render on my model. I filled the presenter with materials, and I click on the rendering botton.
The render started and when he process an outsized area, Navisworks stop working properly and I can't get my render.
I would like to know what is the probleme and how I can fix it?
Thanks for your help.
I work on Navisworks Simulate 2013 SP2, my computer have 16Go of RAM and an Intel I7 Processor.
Materials can be very hardware-intensive for rendering. Depending on the number of objects in your scene, number of materials, materials properties, etc. you could be exceeding the capability of your hardware. Have a look at the RAM use during rendering - its probably max'ed out.
My RAM isn't max'ed out, I'm using 9GB of 16 and.
I'm trying different solutions and I can realize my rendering in low quality.
When I'm trying in Middle or High quality navisworks is crashing.
Do you have any idears?
I have news, I'm trying in high quality with all properties but without anti-aliasing and my rendering is going to the end properly.
Why the anti aliasing break probleme?
Thanks fot your help
Hello there,
the option to disable antialiasing... I had the same problem some time ago.
Chose to render in Showcase instead because of the program crashing or
refusing to generate any output file
Why this happens I don´t know, but you definitely brightened up my day.
Kind regards
Daniel
