Navisworks General Discussion
Member
LMEAxens
Message 1 of 5 (251 Views)
Navisworks Simulate 2013 render problem
251 Views, 4 Replies
02-11-2014 04:39 AM
I need your help, I have to make a render on my model. I filled the presenter with materials, and I click on the rendering botton.
The render started and when he process an outsized area, Navisworks stop working properly and I can't get my render.
I would like to know what is the probleme and how I can fix it?
Thanks for your help.
I work on Navisworks Simulate 2013 SP2, my computer have 16Go of RAM and an Intel I7 Processor.
Ludovic
dgorsman
Message 2 of 5 (235 Views)
Re: Navisworks Simulate 2013 render problem
02-11-2014 08:20 AM in reply to: LMEAxens
Materials can be very hardware-intensive for rendering.  Depending on the number of objects in your scene, number of materials, materials properties, etc. you could be exceeding the capability of your hardware.  Have a look at the RAM use during rendering - its probably max'ed out.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Member
LMEAxens
Message 3 of 5 (212 Views)
Re : Navisworks Simulate 2013 render problem
02-13-2014 05:22 AM in reply to: LMEAxens
My RAM isn't max'ed out, I'm using 9GB of 16 and.
I'm trying different solutions and I can realize my rendering in low quality.
When I'm trying in Middle or High quality navisworks is crashing.
Do you have any idears?
Ludovic
Member
LMEAxens
Message 4 of 5 (204 Views)
02-13-2014 06:29 AM in reply to: LMEAxens
I have news, I'm trying in high quality with all properties but without anti-aliasing and my rendering is going to the end properly.
Why the anti aliasing break probleme?
Thanks fot your help
Ludovic
Valued Mentor
Logos_Atum
Message 5 of 5 (200 Views)
Betreff: Navisworks Simulate 2013 render problem
02-13-2014 07:51 AM in reply to: LMEAxens
Hello there,
the option to disable antialiasing... I had the same problem some time ago.
Chose to render in Showcase instead because of the program crashing or
refusing to generate any output file
Why this happens I don´t know, but you definitely brightened up my day.
Kind regards
Daniel
- 2500K @ 4.2Ghz- 8GB - Radeon7970 -
- Xeon 1230V2 @ stock Ghz- 32GB - W7000-
- 2x Xeon 2670V2 - 64GB - W7000 - 4x Quadro 2000 - oh yes -
- Factory Design Suite Premium Subscription-
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Ask the Community
