I was wondering when Navisworks Freedom 2013 and the NWC Export downloads will be available? Obviously Navisworks Freedom is available in the Deployment Image creation of Navisworks Manage and Simulate but why isnt it available as separate downloads? I want to be able to build these as packages for all the products we use so we can deploy via SMS / SCCM.
Duncan
Solved by john.lipp. Go to Solution.
Hi DuncanBrannan82
The 2013 version of the Autodesk Navisworks NWC Export Utility and Navisworks Freedom 2013 are not yet available for download off of the http://www.autodesk.com/navisworks page, but these should be coming soon. I would check back periodically in the upcoming days.
I'll make a note to update your post here once they are available. For the time being, as you mentioned, you are able to install just these components if you like from the main product installer of Navisworks Manage or Navisworks Simulate.
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
Hi DuncanBrannan82
The NWC File Export Utility and the Download Navisworks Freedom links on the Navisworks page both are now linked to the 2013 versions.
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
The Freedom installer now contains a *working* deployment creator. Yeah!
