I am developing a plugin for Navisworks Manage 2013 in VB.Net (Framework 4). The addin will onvoke a windows form.
On a button click event, I create an Instance of a class.
Private Sub btnFolder_Click(sender As Object, e As EventArgs) Handles btnFolder.Click
Dim formSpreadInfo As New SpreadFileInfo
End Sub
SpreadFileInfo is a VB class file , located in another solution. the application crashes when I click this button.
I had sent the error report to Autodesk, and was advised to INstall SP2, Which I did. The problem still persists.
I have sent an error report post installing SP2 - CER_81691444
Development environment: (Windows 7 64 Bit).
1) Visual Studio 2012 , Framework 4.0, VB.Net
2) NavisWorks Manage 2013.
3) Navis Plugin Project compile settings ->AnyCPU
4) Other Projects within the solution have Compile Settings ->X86.
Navis plug in does not load when compiled for 32 bit systems.
Thanks in anticipation.
Arun S
