Navisworks General Discussion
dgorsman
Message 21 of 23 (205 Views)
Re: Navisworks Manage 2012 and 3d Connexion issue
04-25-2012 09:57 AM in reply to: arch
Default speeds are a bit of a trade off; try to go faster and you will likely see the problem worsen, but make it slower and it takes forever to get anywhere in the mdoel.
Try the far clipping planes to reduce distant objects.  It's not ideal as it can strip out context but the reduction in the number of objects to refresh on-screen can help.  Also maybe increasing the "Number of pixels below which objects are culled".  I think the default is 1 pixel, increasing that value will cause some objects to drop-out should improve performance somewhat.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Mentor
Rich.O.3d
Message 22 of 23 (185 Views)
05-07-2012 11:21 PM in reply to: JasonHarden1705
what OS are you using
If its XP then this will not get fixed...its an instruction set for directx issue.
Neither microsoft or 3dconnection intend adding these missing bits of code to there software/drivers.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
New Member
LudvigLoven
Message 23 of 23 (154 Views)
09-28-2012 01:56 AM in reply to: JasonHarden1705
Has anyone gotten anywhere with this? I'm still experiencing this problem with Navisworks Manage 2013 SP2 and a SpaceNavigator.
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Ask the Community
