Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks Exporters 2013 Multilingual Win.exe -- will not install
3 REPLIES 3
freelancette
2122 Views, 3 Replies
I have tried twice to download & install the Exporters 2013 and it will not work for me.  The installation sequence stops HERE:
Extracting setup\upiconfig.xml
Extracting x64\NWEXPORT\Autodesk\Navisworks 2013 64 bit Exporter Plug-ins\MRF\Setup\Setup\upiconfig.xml
Extracting x86\NWEXPORT\Autodesk\Navisworks 2013 32 bit Exporter Plug-ins\MRF\Setup\Setup\upiconfig.xml
Extracting 3rdParty\Source\sharpziplib.zip
CRC failed in 3rdParty\Source\sharpziplib.zip
Unexpected end of archive
and then I get this message:
“Some installation files are corrupt.  Please download a fresh copy and retry the installation.”
and also:
"This program might not have installed correctly.
If this program didn’t install correctly, try reinstalling using settings that are compatible with this version of Windows.
  • Reinstall using recommended settings
  • This program installed correctly"
I tried to reinstall -- no luck.  Downloaded again and tried again -- no luck.
Does anyone know of an obvious solution to this?
I have Windows 7 - 64 bit.  Was able to install the Service Pack 2.
Thank you!
3 REPLIES 3
freelancette
in reply to: freelancette
Problem solved.  I contacted my reseller MicrosolResources.  They directed me to download the Exporters from this page on Autodesk's website (and it worked this time):
www.autodesk.com/navisworks-nwcexportutility
Previously I had logged in on subscription and found it on this page below Service Pack 2:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=20458011&linkID=10382102&siteID=123112
Is it possible they are two different versions?  I don't know, but the former worked, while the latter did not.
Chris.Aquino
The end of archive error message means that the download either did not finish or was somehow corrupt.
Thank you for letting everyone know how you resolved your issue.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
Can believe it took me this long to find this.  Been looking for the exporters off and on over the last 6 months. Way to post a great answer.
Doh.
Rail Community
