It appears that Navisworks does not import in any AutoCAD MEP custom MvPart properties sets from style. Data is not found under the Properties tab in the Selection Tree. Does anyone know a trick to get this type of data imported into Navisworks?
We have users that place tag information for MvParts in the Custom_TypeStyles properties. Any help is appreciated.
Solved by alan.quinn. Go to Solution.
Unfortunately this is a known issue that development is working on. This will require a code change to address. I checked the internal case and no date was given on when the changes will be make or when we can expect to see them. In the meantime all I can offer it the Product Contact link. I’d suggest leaving feedback at the below link. Information gathered is used to improve the application.
Product Contact Link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thanks for posting.
Thanks for the update. Hopefully this is addressed in the next version release of Navisworks.
