Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navis2013 Show Grids not working properly
5 REPLIES 5
david.byrnes
548 Views, 5 Replies
Just discovered the new Show Grid button on the 2013 View tab. After a couple of successful appends, it's stopped working. The attached PNG shows the grid on a 54m conveyor gallery toggled on. At the same time, the dropdown selector shows that it's the electrical room, not the 54m gallery that's actually selected. And I am unable to move the selection off the electrical room to any other appended project.
Anyone else run into this? Seems like a bug to me...
5 REPLIES 5
john.lipp
in reply to: david.byrnes
Hi david.byrnes
If you delete the 314X 19-ElectricalRoom-CENTRAL.rvt file in the selection tree, does it then allow another file’s grids to be selected?  If so, can you append the file back after deleting and does the issue no longer occur?
Is the issue only occurring when loading the NWF? If you click Application Button > New, and click application button > Open and load those same RVT files listed in the selection tree, does the issue return?
If so, if you create a new project and append the RVT files, one by one and check the drop downs functionality, does it occur when appending one of the specific RVT files?
Best regards
John Lipp
Support Specialist
Product Support
john.lipp
in reply to: john.lipp
Also, please ensure you've installed the service pack 2 over Navisworks 2013:
http://usa.autodesk.com/getdoc/id=DL20458011
david.byrnes
Pretty sure SP2 is installed - About says "Navisworks Version 10.2.0.91043 Sep 7 2012.
john.lipp
You build is stated as that after installing Service Pack 2.
Did deleting any of those files cause the dropdown to function properly?  Does it occur if you create a new project and open all the files again at once.
david.byrnes
It's pretty hard to figure out what's going on. I deleted the electrical room, then I changed the grid selection a few times - which worked each time - and then it didn't work; got stuck again on a different rvt while displaying the grid of the previously selected rvt.
Also tried appending the revit projects to a new nwf, and after 3 or 4 or 5 appends, the same thing started happening. There does not seem to be one particular rvt on which it fails.
Rail Community
