Hi Folks,
I am having issues opening a 393MB NWD file on one of our laptops. It is a Win 7, with 16GB memory and an i7 chip.
when I open the NWD from the local hard drive it takes about 20 minutes to open. The initilal opening phase of the file is quick but about a minute in it slows significantly. I have checked out the roamer.exe process while it is trying to open this file and it seems to slow down at the same point which is when it hits about 1.5GB of memory usage.
To confuse matters, I have an identical laptop, same spec etc, that opens the same file from the local hard drive in about 2 minutes. Are there any settings I can check that might help with this issue?
Regards
Ciaran
