Navis 2012 - SP1
Initial xml import of Quick Properties - but even after deleting all the entries and recreating the entries by hand you end up with the same condition (as shown in graphics) gridview of "ok" List view is incorrect.
Hi gregoryx.robinson
I was able to reproduce the issue with Navisworks 2012 with Service Pack 1 installed. When I attempt to add a property for the “Attribute” category in the list view, it reverts to a different property. When I check the grid view, the property is correct.
When I turn on quick properties in Navisworks and hover over an item, the correct property (the one from the tabbed view) is being displayed.
I tested this behavior with Navisworks 2013 with Service Pack 1 installed, and it doesn’t occur. I would recommend upgrading to this latest version.
When you activate quick properties in Navisworks and hover over the element in the view, is the quick property the correct one from the grid view?
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
Thank you John,
While the solution provided is to upgrade, there is cost and manhour resources associated with said remedy.
Procurement stipulated the contract standard is to be 2012.
So at this time your recommendation can not be implemented.
We would however appreciate the code being fixed.
Greg
Are the properties displaying correctly in the Scene View when you turn on quick properties and match those in the grid view?
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
